メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Roofing Tile Replacement
必要な工具と部品
  1. Roofing Tile  Replacement, Roofing Tile: 手順 1、 1の画像 1
    • Be cautious when climbing the ladder to the roof. Ensure your ladder is secure before climbing.
    • Ensure the damage has not reached the underlayment.
  2. Roofing Tile  Replacement: 手順 2、 1の画像 1
    • Depending on where the damaged tile is on the roof, be sure to prime underlayment before adding new roof tile on top.
  3. Roofing Tile  Replacement: 手順 3、 1の画像 1
    • Carefully remove the damaged tile(s) using your hammer and crowbar.
    • Be sure to use an effective safety harness when operating in unsafe conditions.
  4. Roofing Tile  Replacement: 手順 4、 1の画像 1
    • Use roof cement to initially attach the tiles to each other and add security to the underlayment.
    • Be sure to wear the proper gear, such as shoes, hats, & breathable clothing.
  5. Roofing Tile  Replacement: 手順 5、 3の画像 1 Roofing Tile  Replacement: 手順 5、 3の画像 2 Roofing Tile  Replacement: 手順 5、 3の画像 3
    • Secure the tile to the cement by pressing down on the tile using the handle of the hammer.
    • Use the handle of the hammer to maneuver into correct position.
    • As seen in the bottom of the picture, using too much cement can leak out from both sides of the tile. Be sure to keep it as hidden underneath the tile as possible.
    • Safety first. Don't forget to wear a harness and be sure to understand handling of cement take.
  6. Roofing Tile  Replacement: 手順 6、 1の画像 1
    • Walk carefully on the tiles that are already set into place.
  7. Roofing Tile  Replacement: 手順 7、 1の画像 1
    • Use the backside of the hammer to slide up the piece overlapping the broken one, and use a drill to unscrew any screws (which won't be necessary if you're using roof cement). Replace the tile with the new one, and glue in place.
  8. Roofing Tile  Replacement: 手順 8、 1の画像 1
    • This is an initial point of view for replacing a single broken tile. You can see the application of roof cement in the crevice of the tile.
終わりに
Number one thing of importance is your safety, my goal is for this guide to give you a general idea of the steps it takes to construct/repair/replace a tile roof.
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jonathan Fuentes
メンバー登録日: 01/13/20
187 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020人のメンバー
USFSM-STEWART-S20S1G1
23 メンバー
33のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 34
過去 30 日: 108
今までの合計 1,490
