はじめに
This guide will show you how to replace the dial caps on your Roland TR-505.
To reassemble perform steps in reverse.
Simply firmly hold the cap and carefully pull up and the cap should pop up.
Bonus Step!
While the cap is off it can be worth cleaning under the cap to prevent dirt from getting inside.
This whole guide applies for both dials as they both come off the same way.
Thanks for reading:-)
ある他の人がこのガイドを完成しました。
