メインコンテンツにスキップ
はじめに
In this guide, we'll show you how to replace a faulty power port on the Roku XD 2050X. To complete this guide, you will need to disassemble your device and use a soldering iron to replace the port.
パーツ
パーツは指定されていません。
  1. Ensure the Roku XDis unplugged. Take care when handling components.  Circuit boards, soldering points, and other areas may have sharp points. Turn the device upside down.
    • Ensure the Roku XDis unplugged.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Turn the device upside down.
    • Remove the two rubber pads using a plastic spudger.
  2. Remove the two Phillips #1 9mm pan-head screws. Remove the two Phillips #1 9mm pan-head screws.
    • Remove the two Phillips #1 9mm pan-head screws.
  3. Apple Watch キット
    スクリーンとバッテリー の修理が簡単にできます。
    ショップを見る
    Apple Watch キット
    ショップを見る
  4. Insert spudger between upper and lower frame underneath the port access. Guide spudger around to loosen upper and lower frame to pry frame apart. Gently remove upper frame.
    • Insert spudger between upper and lower frame underneath the port access.
    • Guide spudger around to loosen upper and lower frame to pry frame apart.
    • Gently remove upper frame.
  5. Remove the two Phillips #1 8mm pan-head screws. Remove the two Phillips #1 8mm pan-head screws.
    • Remove the two Phillips #1 8mm pan-head screws.
  6. On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • Lift the motherboard out of the lower frame.
  7. Desolder the 3 contact points.
    • Desolder the 3 contact points.
    • Remove the power port from the motherboard.
    • For help with soldering view the iFixit soldering guide.
まとめ
ある他の人がこのガイドを完成しました。
William
メンバー登録日: 2015年01月30日
1,483 ポイント
10のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-6, Rountree Winter 2015 University of Kentucky Louisville, Team 1-6, Rountree Winter 2015人のメンバー
LOUISVILLE-ROUNTREE-W15S1G6
4 メンバー
10のガイドは作成済み
Where do you buy power port ?
John - 返信
For Roku 2 XS
John - 返信
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 850
