メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The Roku Streaming Stick remote is a device that is used to control the operation of the Roku from a distance. This guide will provide instructions on how to replace the macro buttons.
  1. Place the remote so that the battery cover is facing upwards.
    • Place the remote so that the battery cover is facing upwards.
  2. Remove the battery cover to expose the battery compartment.
    • Remove the battery cover to expose the battery compartment.
  3. Remove batteries.
    • Remove batteries.
  4. Use a Phillips #00 screwdriver to remove the 1.5 mm wide screw.
    • Use a Phillips #00 screwdriver to remove the 1.5 mm wide screw.
  5. Use a plastic opening tool to gently pry apart the plastic enclosure.  Make sure you create a large enough gap before you attempt to separate the two pieces. Use a plastic opening tool to gently pry apart the plastic enclosure.  Make sure you create a large enough gap before you attempt to separate the two pieces.
    • Use a plastic opening tool to gently pry apart the plastic enclosure. Make sure you create a large enough gap before you attempt to separate the two pieces.
  6. Gently remove the circuit board or motherboard.
    • Gently remove the circuit board or motherboard.
  7. First, gently remove the three plastic sheets. Then, remove the button panels from the remote control.
    • First, gently remove the three plastic sheets. Then, remove the button panels from the remote control.
    • Repair the contact sheet as noted on the Button Contact Repair Kit listed above. Otherwise replace with new conductive button contacts.
終わりに
Feliciano Bandazi
メンバー登録日: 2018年04月07日
145 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G2, Wilson Spring 2018 IUPUI, Team S2-G2, Wilson Spring 2018人のメンバー
IUPUI-WILSON-S18S2G2
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 57
今までの合計 1,675
