メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Roku 4 Motherboard Replacement
必要な工具と部品
    1. Roku 4 Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
      • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
      FixBotに聞いてみる
      コメントを追加
    2. Roku 4 Motherboard Replacement: 手順 2、 1の画像 1
      • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
      • Completely remove the rubber sticker to reveal the underlying screws on the device.
      • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
      FixBotに聞いてみる
      コメントを追加
    3. Roku 4 Motherboard Replacement: 手順 3、 1の画像 1
      • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
      • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
      FixBotに聞いてみる
      コメントを追加
    4. Roku 4 Motherboard Replacement: 手順 4、 2の画像 1 Roku 4 Motherboard Replacement: 手順 4、 2の画像 2
      • Turn the device over so you can see the "4" on the top cover.
      FixBotに聞いてみる
      コメントを追加
    5. Roku 4 Motherboard Replacement: 手順 5、 2の画像 1 Roku 4 Motherboard Replacement: 手順 5、 2の画像 2
      • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
      • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
      FixBotに聞いてみる
      コメントを追加
    6. Roku 4 Motherboard Replacement: 手順 6、 1の画像 1
      • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
      • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
      FixBotに聞いてみる
      コメントを追加
    7. Roku 4 Motherboard Replacement: 手順 7、 3の画像 1 Roku 4 Motherboard Replacement: 手順 7、 3の画像 2 Roku 4 Motherboard Replacement: 手順 7、 3の画像 3
      • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
      • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
      FixBotに聞いてみる
      コメントを追加
    8. Roku 4 Motherboard Replacement: 手順 8、 3の画像 1 Roku 4 Motherboard Replacement: 手順 8、 3の画像 2 Roku 4 Motherboard Replacement: 手順 8、 3の画像 3
      • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
      • Repeat this step for the strip that attaches the black and red wires to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    9. Roku 4 Motherboard Replacement: 手順 9、 3の画像 1 Roku 4 Motherboard Replacement: 手順 9、 3の画像 2 Roku 4 Motherboard Replacement: 手順 9、 3の画像 3
      • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
      • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
      • The motherboard should now be completely disconnected from the top cover of the device.
      FixBotに聞いてみる
      コメントを追加
終わりに
Follow these steps in the reverse order to reassemble your device.
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Bradley Rains
メンバー登録日: 03/26/17
166 ポイント
1ガイドが承認済み
チーム
Baylor, Team S5-G4, Williams Spring 2017 Baylor, Team S5-G4, Williams Spring 2017人のメンバー
BU-WILLIAMS-S17S5G4
3 メンバー
8のガイドは作成済み
4件のガイドコメント
Thank you, have you upgraded to a new 2019 Ultra model yet?
Allan Landwer - 返信 共有
Soldering the fan to the mobo is a suck move. However, they used a good quality bearing-less fan.
smbrannon - 返信 共有
Can you gve me areson? will it suck out the perfomance?
Kind-hearted, spirited Man - 返信 共有
Because it makes replacing the motherboard more difficult. For a few cents more, they could have placed a small connector inline between the fan and motherboard, making disconnecting the fan and top case really easy.
Bob Reed - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 44
今までの合計 6,393
