メインコンテンツにスキップ
Roku 3 Remote Control Motherboard Replacement
必要な工具と部品
  1. Roku 3 Remote Control Motherboard Replacement, Remote Control Battery: 手順 1、 1の画像 1
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
  2. Roku 3 Remote Control Motherboard Replacement: 手順 2、 2の画像 1 Roku 3 Remote Control Motherboard Replacement: 手順 2、 2の画像 2
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
  3. Roku 3 Remote Control Motherboard Replacement: 手順 3、 1の画像 1
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
  4. Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: 手順 4、 2の画像 1 Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: 手順 4、 2の画像 2
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
  5. Roku 3 Remote Control Motherboard Replacement: 手順 5、 2の画像 1 Roku 3 Remote Control Motherboard Replacement: 手順 5、 2の画像 2
    • Gently pry open the remote using the plastic opening tool.
  6. Roku 3 Remote Control Motherboard Replacement: 手順 6、 2の画像 1 Roku 3 Remote Control Motherboard Replacement: 手順 6、 2の画像 2
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
  7. Roku 3 Remote Control Motherboard Replacement: 手順 7、 1の画像 1
    • Set aside the half of the remote with the buttons.
    • Take the the other half of the remote with one hand and remove the motherboard with your thumb and forefinger of the other hand.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Isobelle Espiritu
メンバー登録日: 10/06/16
591 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 15-2, Livingston Fall 2016 Cal Poly, Team 15-2, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S15G2
3 メンバー
6のガイドは作成済み
4 件のコメント
Thanks for the tutorial. Any idea where I can buy the motherboard for the Roku 3 remote?
Bret Dennis - 返信
Where can I buy a Roku 3 remote motherboard replacement?
A. J. Sitarsky - 返信
Hi, wondered if you had any luck locating a motherboard for the Roku 3? Thanks!
Paul Cacioppo -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 32
今までの合計 5,335
