はじめに
If your mouse start to register double-click when you click only once, this might be a worn switch.
必要な工具と部品
All screw are hidden below the mouse
Peel off the mouse pad to uncover 5 of the 6 screws
The last screw is in a hole under the sticker. You don't need to remove the whole sticker to uncover it.
remove the last screws and pull the board free
the mouse wheel LED assembly is a separate piece you need to unscrew.
I want to change the left switch.
flip the board to unsolder the switch.
Only two legs are soldered, this is the third one
The new switch replace the old one not working.
The button should be on the left
7 の人々がこのガイドを完成させました。
コメント 1 件
Greetings,
Would you happen to know the part number for the x-celerator paddle potentiometer replacement?
Thanks!
