メインコンテンツにスキップ
Roborock Q5 Pro: Laser Distance Sensor Replacement
必要な工具と部品
  1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: 手順 1、 3の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: 手順 1、 3の画像 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: 手順 1、 3の画像 3
    • Flip it on its head, then remove the dustbin.
  2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bottom cover.: 手順 2、 2の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bottom cover.: 手順 2、 2の画像 2
    • Remove the side brush using a PH2 screwdriver.
    • Remove the screws using a PH2 screwdriver.
    • Then, pull the bottom cover off.
  3. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: 手順 3、 3の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: 手順 3、 3の画像 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: 手順 3、 3の画像 3
    • Lift it up on the left.
    • Detach the connector by squeezing the release tab, then pull it out.
    • Do not simply yank the battery out. You will tear the connector off the motherboard.
  4. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper's lid.: 手順 4、 2の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper's lid.: 手順 4、 2の画像 2
    • Remove the marked screws using a PH1 screwdriver.
    • Then simply lift the lid off.
  5. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper.: 手順 5、 2の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper.: 手順 5、 2の画像 2
    • Flip the robot over.
    • Tilt the bumper forwards and move it upwards to remove it.
  6. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the side brush motor.: 手順 6、 1の画像 1
    • Flip it back over.
    • Simply lift it out.
  7. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the chassis screws.: 手順 7、 1の画像 1
    • Remove the marked screws using a PH2 screwdriver.
  8. Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: 手順 8、 3の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: 手順 8、 3の画像 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: 手順 8、 3の画像 3
    • The chassis will still be held together by a couple latches on the back.
    • Use a prying tool to get these apart before taking it apart.
  9. Roborock Q5 Pro: Laser Distance Sensor Replacement, Take it apart!: 手順 9、 2の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Take it apart!: 手順 9、 2の画像 2
    • Flip it over and simply pull the chassis halves apart.
  10. Roborock Q5 Pro: Laser Distance Sensor Replacement, Screeeeeeews.: 手順 10、 1の画像 1
    • Here are the screws organised by steps and type.
    • Use this if needed as a reference during reassembly.
  11. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: 手順 11、 3の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: 手順 11、 3の画像 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: 手順 11、 3の画像 3
    • Then, remove it.
  12. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: 手順 12、 3の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: 手順 12、 3の画像 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: 手順 12、 3の画像 3
    • Lift the LDS towards the right, then disconnect the connector.
    • If you're replacing the LDS, simply insert the new one and reassemble your device.
  13. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: 手順 13、 3の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: 手順 13、 3の画像 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: 手順 13、 3の画像 3
    • Remove the rubber band using some tweezers, forceps or your fingers.
    • Make sure to clean it. This one was quite dirty, which was causing the motor to seize.
    • Your robot may have a different iteration of the LDS, which has a cover over the rubber band section. In that case, please check: Roborock Q Revo: Laser Distance Sensor Replacement and skip to step 12.
  14. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: 手順 14、 3の画像 1 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: 手順 14、 3の画像 2 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: 手順 14、 3の画像 3
    • Before removing the motor, flip it over and check whether it has a connector or is soldered directly onto the PCBA.
    • Remove the screws.
    • Now you can remove and replace the motor.
    • Your robot may have a different iteration of the LDS, which needs it's driving wheel removed before you can remove the screws. In that case, please check: Roborock Q Revo: Laser Distance Sensor Replacement and skip to step 12.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
DegenFixer
メンバー登録日: 09/18/24
5,111 ポイント
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 127
過去 30 日: 447
今までの合計 4,727
