はじめに
This guide will help you remove the motor and requires the uses of a soldering iron. Check out this soldering guide for help if you don't know how to solder.
必要な工具と部品
Twist the plastic lid counterclockwise to unlock it.
Lift the lid to remove it from the container.
Use a soldering kit to remove solder from the circuit board for the red wire.
Follow this soldering guide if you need extra help!
3 の人々がこのガイドを完成させました。
