メインコンテンツにスキップ
Rival CM4015 Water Tubes Replacement
必要な工具と部品
  1. Rival CM4015 Water Tubes Replacement, Base Plate: 手順 1、 2の画像 1 Rival CM4015 Water Tubes Replacement, Base Plate: 手順 1、 2の画像 2
    • Remove the three 16 mm tri-point screws from the base plate.
  2. Rival CM4015 Water Tubes Replacement: 手順 2、 2の画像 1 Rival CM4015 Water Tubes Replacement: 手順 2、 2の画像 2
    • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
  3. Rival CM4015 Water Tubes Replacement, Power Button: 手順 3、 1の画像 1
    • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
  4. Rival CM4015 Water Tubes Replacement: 手順 4、 2の画像 1 Rival CM4015 Water Tubes Replacement: 手順 4、 2の画像 2
    • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
    • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
  5. Rival CM4015 Water Tubes Replacement: 手順 5、 2の画像 1 Rival CM4015 Water Tubes Replacement: 手順 5、 2の画像 2
    • Clean both the button and its slot before replacing the power button.
  6. Rival CM4015 Water Tubes Replacement, Heating Element: 手順 6、 1の画像 1
    • Remove the two 8 mm Phillips screws from the plastic body.
  7. Rival CM4015 Water Tubes Replacement: 手順 7、 2の画像 1 Rival CM4015 Water Tubes Replacement: 手順 7、 2の画像 2
    • Remove the two 8 mm Phillips screws from the chassis of coffee maker.
    • Pull back the metal backing from the plastic body.
  8. Rival CM4015 Water Tubes Replacement: 手順 8、 3の画像 1 Rival CM4015 Water Tubes Replacement: 手順 8、 3の画像 2 Rival CM4015 Water Tubes Replacement: 手順 8、 3の画像 3
    • Remove the four 8 mm Phillips screws from the inner plastic body.
    • You will need a long, thin Phillips screw driver to get this deep into the device.
  9. Rival CM4015 Water Tubes Replacement: 手順 9、 2の画像 1 Rival CM4015 Water Tubes Replacement: 手順 9、 2の画像 2
    • Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
    • Take your time to make sure the thin cables within the device don't tear.
  10. Rival CM4015 Water Tubes Replacement: 手順 10、 1の画像 1
    • Remove the two 8 mm Phillips screws from the metal backing.
  11. Rival CM4015 Water Tubes Replacement: 手順 11、 1の画像 1
    • Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
    • You may also use pliers for this step if the springs are too strong.
  12. Rival CM4015 Water Tubes Replacement: 手順 12、 1の画像 1
    • Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
  13. Rival CM4015 Water Tubes Replacement, Water Tubes: 手順 13、 1の画像 1
    • Remove the two rubber water tubes from the heating element by firmly pulling each at a 90 degree angle from the socket.
終わりに
作成者
2人の作成者と共同で作成されました。
Michael Murdock
メンバー登録日: 10/06/16
279 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-6, Livingston Fall 2016 Cal Poly, Team 10-6, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S10G6
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 239
