はじめに
This guide will give detailed steps on how to replace the capacitor in the Ring Video Doorbell Pro.
必要な工具と部品
Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
Remove the speaker from the device.
The next step is to remove the last four connections holding the motherboard in place.
Using the plastic pry tool, gently ease this ribbon cable from its port.
Take the motherboard out of the housing. Lift slowly while doing this to make sure the wires and the delicate ribbon cable are not damaged.
Remove the capacitor.
CAUTION:
You need to add to the ribbon cable removal that the ribbon cable pulls out of the white socket. Do not pry up on the white socket as you will break the soldier connections.
To reassemble your device, insert the new capacitor and follow these instructions in reverse order.
5 の人々がこのガイドを完成させました。
8 件のコメント
where can I buy the replacement capacitor please or is it a case of buying a standard and making up the lead?
is that a battery right next to it? why didn’t you pull/mention that also?
I have the ring pro. What is the battery specification and what is the capacitor specification? If I going to all that work I need the replacement parts on hand.
The capacitor is a 470 uF/ 50 VDC electrolytic capacitor.
Battery is 350 mAh 3.7 volt Li 602030.
602030 battery listing: https://www.aliexpress.com/item/33029703...
tmiller -
Respond to Kent’s questions please!!!!
Where can I get a new glass plate? Delivery people have broken the glass. Picture and everything works fine.
CAUTION:
