メインコンテンツにスキップ
Ring Video Doorbell Battery Replacement
必要な工具と部品
  1. Ring Video Doorbell Battery Replacement, Battery: 手順 1、 3の画像 1 Ring Video Doorbell Battery Replacement, Battery: 手順 1、 3の画像 2 Ring Video Doorbell Battery Replacement, Battery: 手順 1、 3の画像 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Battery Replacement: 手順 2、 3の画像 1 Ring Video Doorbell Battery Replacement: 手順 2、 3の画像 2 Ring Video Doorbell Battery Replacement: 手順 2、 3の画像 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Abdulrahman
メンバー登録日: 02/20/18
685 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S11-G5, Cheng Spring 2018 USF Tampa, Team S11-G5, Cheng Spring 2018人のメンバー
USFT-CHENG-S18S11G5
3 メンバー
10のガイドは作成済み
4 件のコメント
Where do I get a replacement battery?
William Price - 返信
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - 返信
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - 返信
can it be sent to the manufacturers for a replacement
d.rayyan - 返信
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 84
過去 30 日: 346
今までの合計 8,633
