はじめに
This guide begins after completing the motherboard replacement guide. All you will need for speaker replacement is a plastic opening tool. Speaker replacement may be needed if you are having sound issues.
必要な工具と部品
Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
Pry open the aluminium plate using the Plastic Opening Tool(s).
Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
ある他の人がこのガイドを完成しました。
コメント 1 件
Where does one get replacement speakers for the 88RG000FC100 ring doorbell?
