メインコンテンツにスキップ
Ring Stick Up Cam Speakers Replacement
必要な工具と部品
  1. Ring Stick Up Cam Speakers Replacement, Battery: 手順 1、 1の画像 1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Speakers Replacement: 手順 2、 1の画像 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Speakers Replacement: 手順 3、 1の画像 1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Speakers Replacement: 手順 4、 1の画像 1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Speakers Replacement: 手順 5、 1の画像 1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Speakers Replacement: 手順 6、 1の画像 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  7. Ring Stick Up Cam Speakers Replacement, Camera: 手順 7、 1の画像 1
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
  8. Ring Stick Up Cam Speakers Replacement: 手順 8、 1の画像 1
    • Disconnect the ribbon connector shown in the photo.
  9. Ring Stick Up Cam Speakers Replacement: 手順 9、 1の画像 1
    • Remove the motherboard from the device by hand.
  10. Ring Stick Up Cam Speakers Replacement: 手順 10、 1の画像 1
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
  11. Ring Stick Up Cam Speakers Replacement: 手順 11、 1の画像 1
    • Remove the three plastic spacers shown in the photo by hand.
  12. Ring Stick Up Cam Speakers Replacement: 手順 12、 1の画像 1
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
  13. Ring Stick Up Cam Speakers Replacement: 手順 13、 1の画像 1
    • Lift the camera board out of the housing using your hand.
  14. Ring Stick Up Cam Speakers Replacement, Microphone: 手順 14、 1の画像 1
    • Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
  15. Ring Stick Up Cam Speakers Replacement: 手順 15、 1の画像 1
    • Use a plastic opening tool to carefully pry the microphone from the housing.
  16. Ring Stick Up Cam Speakers Replacement: 手順 16、 1の画像 1
    • Use your hands to remove the daughterboard containing the microphone from the housing.
  17. Ring Stick Up Cam Speakers Replacement, Speakers: 手順 17、 1の画像 1
    • Using a plastic opening tool, remove both of the speakers.
終わりに
作成者
2人の作成者と共同で作成されました。
Chunyue Liu
メンバー登録日: 02/06/19
273 ポイント
2のガイドは作成済み
チーム
UC Davis, Team S18-G3, Lore Winter 2019 UC Davis, Team S18-G3, Lore Winter 2019人のメンバー
UCD-LORE-W19S18G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 11
今までの合計 1,071
