メインコンテンツにスキップ
Ring Stick Up Cam Battery Microphone Replacement
必要な工具と部品
  1. Ring Stick Up Cam Battery Microphone Replacement, Battery: 手順 1、 1の画像 1
    • Turn the camera so the lens is facing away from you, and the back is facing towards you.
    • Place one hand securely on the base and the other on the stand.
    • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
  2. Ring Stick Up Cam Battery Microphone Replacement: 手順 2、 1の画像 1
    • Gently pull down to separate the stand from the camera body.
  3. Ring Stick Up Cam Battery Microphone Replacement: 手順 3、 2の画像 1 Ring Stick Up Cam Battery Microphone Replacement: 手順 3、 2の画像 2
    • Hold the camera so the opening containing the battery is toward the ceiling.
    • Squeeze the silver lever labeled "push" and extract the battery from its slot.
  4. Ring Stick Up Cam Battery Microphone Replacement, Motherboard: 手順 4、 1の画像 1
    この手順で使用する道具:
    Halberd Spudger
    $2.99
    購入する
    • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
  5. Ring Stick Up Cam Battery Microphone Replacement: 手順 5、 1の画像 1
    • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
  6. Ring Stick Up Cam Battery Microphone Replacement: 手順 6、 1の画像 1
    • Rotate the device so the base is facing upward.
    • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
    • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
  7. Ring Stick Up Cam Battery Microphone Replacement: 手順 7、 1の画像 1
    • Remove the silver latch from the base.
    • Remove the front cover.
    • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
    • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
  8. Ring Stick Up Cam Battery Microphone Replacement: 手順 8、 1の画像 1
    • Pry the inside panel open using your hands or a spudger if necessary.
  9. Ring Stick Up Cam Battery Microphone Replacement: 手順 9、 1の画像 1
    • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
  10. Ring Stick Up Cam Battery Microphone Replacement: 手順 10、 2の画像 1 Ring Stick Up Cam Battery Microphone Replacement: 手順 10、 2の画像 2
    • Lift the motherboard from the camera body with the halberd spudger.
  11. Ring Stick Up Cam Battery Microphone Replacement: 手順 11、 2の画像 1 Ring Stick Up Cam Battery Microphone Replacement: 手順 11、 2の画像 2
    • Rotate the device to its side.
    • With your fingers, carefully remove the white part of the cord clip from the beige base.
    • Repeat this for the remaining three cords connecting the motherboard to the camera body.
  12. Ring Stick Up Cam Battery Microphone Replacement: 手順 12、 1の画像 1
    • Fold the motherboard downward from the camera body, revealing a white connecting strip.
    • Using the flat end of a spudger, flick the black hinge upward.
    • Pull the white strip out of the slot.
  13. Ring Stick Up Cam Battery Microphone Replacement: 手順 13、 2の画像 1 Ring Stick Up Cam Battery Microphone Replacement: 手順 13、 2の画像 2
    • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
    • Gently remove the adhesive cover from the motherboard.
  14. Ring Stick Up Cam Battery Microphone Replacement, Camera: 手順 14、 1の画像 1
    • Orient your device so that the interior of the camera body is facing the ceiling.
  15. Ring Stick Up Cam Battery Microphone Replacement: 手順 15、 1の画像 1
    • Remove the two 6 mm screws that connect the camera to the camera body using a Phillips #00 screwdriver.
  16. Ring Stick Up Cam Battery Microphone Replacement: 手順 16、 1の画像 1
    • Grab and twist the camera counterclockwise with your thumb and index finger.
  17. Ring Stick Up Cam Battery Microphone Replacement: 手順 17、 2の画像 1 Ring Stick Up Cam Battery Microphone Replacement: 手順 17、 2の画像 2
    • Using your fingers, lift out the camera component including the camera lens and the attached wire.
  18. Ring Stick Up Cam Battery Microphone Replacement, Microphone: 手順 18、 1の画像 1
    • Remove the two 4 mm screws connecting the metal protective piece to the camera body using a Phillips #00 screwdriver.
  19. Ring Stick Up Cam Battery Microphone Replacement: 手順 19、 1の画像 1
    • Using your fingers, carefully pinch the white connector attached to the black cable, and gently pull it out of its slot on the daughterboard.
  20. Ring Stick Up Cam Battery Microphone Replacement: 手順 20、 1の画像 1
    • Rotate the camera body to a comfortable position.
    • Use the spudger to pry the metal component from the camera body.
    • The daughterboard and microphone should now be exposed.
  21. Ring Stick Up Cam Battery Microphone Replacement: 手順 21、 1の画像 1
    • Gently remove the daughterboard from the base with your hands or the spudger if necessary.
  22. Ring Stick Up Cam Battery Microphone Replacement: 手順 22、 2の画像 1 Ring Stick Up Cam Battery Microphone Replacement: 手順 22、 2の画像 2
    この手順で使用する道具:
    Halberd Spudger
    $2.99
    購入する
    • Use the hook end of the halberd spudger to carefully lift the microphone from the base.
終わりに
作成者
3人の作成者と共同で作成されました。
Caroline Smith
メンバー登録日: 02/24/23
267 ポイント
2のガイドは作成済み
チーム
Marist, Team 1-1, Chaterdon Spring 2023 Marist, Team 1-1, Chaterdon Spring 2023人のメンバー
MARS-CHATERDON-S23S1G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 41
今までの合計 268
