メインコンテンツにスキップ
Ring Outdoor Security Cam Infrared Sensor Replacement
必要な工具と部品
  1. Ring Outdoor Security Cam Infrared Sensor Replacement, Infrared Sensor: 手順 1、 1の画像 1
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
  2. Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 2、 1の画像 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 3、 1の画像 1
    • Using the same tool pry the back plate off of the device.
  4. Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 4、 1の画像 1
    • Disconnect the battery power leads using a plastic opening tool.
  5. Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 5、 1の画像 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  6. Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 6、 1の画像 1
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the three silver 6 mm Phillips #00 screws from the motherboard.
  7. Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 7、 1の画像 1
    • Pull the top of the motherboard up and out of the device.
  8. Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 8、 2の画像 1 Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 8、 2の画像 2
    • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
    • Remove the 3 plastic spacers on the device.
  9. Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 9、 3の画像 1 Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 9、 3の画像 2 Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 9、 3の画像 3
    • Pry the motherboard out with a plastic opening tool.
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
  10. Ring Outdoor Security Cam Infrared Sensor Replacement: 手順 10、 1の画像 1
    • Using a soldering iron to disconnect the connections.
    • Remove the infrared sensor and replace as needed.
終わりに
作成者
4人の作成者と共同で作成されました。
WilliamB22
メンバー登録日: 09/13/23
941 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team 6-2, Kilpatrick Fall 2023 University of North Texas, Team 6-2, Kilpatrick Fall 2023人のメンバー
UNT-KILPATRICK-F23S6G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 15
今までの合計 85
