はじめに
Replace a broken button on a Ring Doorbell Elite
必要な工具と部品
Button on doorbell is broken. Replacement from Etsy Store - Doorbell Accessories
The button is very difficult to replace by disassembly. The seller recommends to pull out the button slightly with your fingers and slide a screwdriver around the seam. I found this didnt work for me
The old button is clipped around the housing with three clips. Cutting the centre of the button out allows easier access to the clips from the inside
Be careful with the cutters to not go too deep and damage the inner circuitry of the button, try to cut parallel to the front of the button
The green ring represents the remains of the old button and the red ring represents the button housing which the button is clipped to
Carefully insert the pointed end of a metal spudger into the gap between the button and the button housing and rotate to seperate the clips from the housing
Then pull back on the button remains as you unclip the clips
The clips are located at 12 oclock , 4 oclock and 8 oclock
Insert the new button with the notch at 6 oclock. It should line up with a tab inside the button ring
Push the button in firmly once lined up. It should not take too much force.
Done!
5 の人々がこのガイドを完成させました。
4件のガイドコメント
Thanks! I found numerous YouTube guides on how to disassemble the whole unit, but will definitely try this method first. If it doesn't work I can always still go the disassembly route as a backup approach.
Tim Reczek - 返信
Supergemakkelijk zelf te doen als je ietswat handig bent. Je hebt enkel een dunne punt tang en klein schroevendraaiertje nodig. Duurde welgeteld 2 min. TOP!
I thought the disassembly option was going to be the only way .
But used this method and it took me 2 mins to replace.
So it's a big yes from me
