メインコンテンツにスキップ
はじめに
A bent SL/SR button board cable will cause the SYNC button, the LED lights and the SL/SR buttons to be unresponsive. This will make the Nintendo Switch Joy-Con unable to connect to a game console by itself without a second Joy-Con.
Before using this guide, determine that the buttons are unresponsive by going to the system settings of the game console and testing the input devices under the 'Controllers and Sensors' section.
  1. Right Joy-Con SL/SR Button Board  Replacement, SL/SR Button Board: 手順 1、 3の画像 1 Right Joy-Con SL/SR Button Board  Replacement, SL/SR Button Board: 手順 1、 3の画像 2 Right Joy-Con SL/SR Button Board  Replacement, SL/SR Button Board: 手順 1、 3の画像 3
    • Remove the four 6 mm screws visible on the back of the Joy-Con using the Tri-point Y00 screwdriver.
    • During the entire procedure, place the small screws somewhere you won't lose them and keep them organized.
  2. Right Joy-Con SL/SR Button Board  Replacement: 手順 2、 3の画像 1 Right Joy-Con SL/SR Button Board  Replacement: 手順 2、 3の画像 2 Right Joy-Con SL/SR Button Board  Replacement: 手順 2、 3の画像 3
    • Open the Joy-Con by inserting the opening pick tool into the bottom corner and sliding it upwards.
    • When opening, be careful not to 'yank' the two halves of the Joy-Con far apart, as they are still attached by cables.
    • The ribbon cables are fragile. Forceful pulling may lead to device damage.
  3. Right Joy-Con SL/SR Button Board  Replacement: 手順 3、 3の画像 1 Right Joy-Con SL/SR Button Board  Replacement: 手順 3、 3の画像 2 Right Joy-Con SL/SR Button Board  Replacement: 手順 3、 3の画像 3
    • Remove the two 3 mm screws on the charging rail using the Phillips #00 screwdriver.
    • The part that needs to be replaced is the button board directly under these two screws.
  4. Right Joy-Con SL/SR Button Board  Replacement: 手順 4、 3の画像 1 Right Joy-Con SL/SR Button Board  Replacement: 手順 4、 3の画像 2 Right Joy-Con SL/SR Button Board  Replacement: 手順 4、 3の画像 3
    • Remove the three 3 mm screw on the battery compartment using the Phillips #00 screwdriver.
    • With the battery compartment loosened, the locking tab holding the cable in place will be easy to access.
  5. Right Joy-Con SL/SR Button Board  Replacement: 手順 5、 3の画像 1 Right Joy-Con SL/SR Button Board  Replacement: 手順 5、 3の画像 2 Right Joy-Con SL/SR Button Board  Replacement: 手順 5、 3の画像 3
    • Use the plastic spudger tool to lift the tab lock holding the bent button board cable. Lightly lift the battery compartment to have more space while doing so.
    • Once the tab is unlocked, remove the bent cable.
  6. Right Joy-Con SL/SR Button Board  Replacement: 手順 6、 3の画像 1 Right Joy-Con SL/SR Button Board  Replacement: 手順 6、 3の画像 2 Right Joy-Con SL/SR Button Board  Replacement: 手順 6、 3の画像 3
    • Insert the new replacement button board cable into the tab.
    • Use the spudger to re-lock the tab to hold the new part in its place.
  7. Right Joy-Con SL/SR Button Board  Replacement: 手順 7、 3の画像 1 Right Joy-Con SL/SR Button Board  Replacement: 手順 7、 3の画像 2 Right Joy-Con SL/SR Button Board  Replacement: 手順 7、 3の画像 3
    • To avoid having the same problem in the future, make sure the new cable is bent under the battery compartment after reassembly.
    • Lightly lift the battery compartment to make it easier to bend the new button board cable under it.
    • The space between the battery and the back shell of the Joy-Con is very tight, which caused the original cable to bend and malfunction. Inserting the new cable under the battery will give it more space.
終わりに
To reassemble your device, follow these instructions in reverse order, starting from Step 4.
ある他の人がこのガイドを完成しました。
Javier Cora
メンバー登録日: 2022年03月18日
181 ポイント
1ガイドが承認済み
チーム
コメント1件
Valuable step-by-step guide plus pictorial samples. Keep writing your good stuff, Javier!
Rudi Lim - 返信
コメントを追加
統計データを表示:
過去 24時間: 31
過去 7 日: 195
過去 30 日: 933
今までの合計 2,928
