メインコンテンツにスキップ
Ridgid R86034 Direction Switch Replacement
必要な工具と部品
  1. Ridgid R86034 Direction Switch Replacement, Disassembling Ridgid R86034 Housing: 手順 1、 1の画像 1
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use some force; the rubber cover is securely attached to the housing.
    • Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
    • Orientation is important when putting the rubber cover on the casing.
  2. Ridgid R86034 Direction Switch Replacement: 手順 2、 2の画像 1 Ridgid R86034 Direction Switch Replacement: 手順 2、 2の画像 2
    • Remove the plastic cover with your hands.
    • There is no need to force off the plastic cover. The plastic cover should be much easier to remove than the rubber cover.
  3. Ridgid R86034 Direction Switch Replacement: 手順 3、 3の画像 1 Ridgid R86034 Direction Switch Replacement: 手順 3、 3の画像 2 Ridgid R86034 Direction Switch Replacement: 手順 3、 3の画像 3
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
  4. Ridgid R86034 Direction Switch Replacement: 手順 4、 2の画像 1 Ridgid R86034 Direction Switch Replacement: 手順 4、 2の画像 2
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
  5. Ridgid R86034 Direction Switch Replacement: 手順 5、 1の画像 1
    • Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger.
    • The housing is easier to remove if you pry from multiple sides.
  6. Ridgid R86034 Direction Switch Replacement: 手順 6、 2の画像 1 Ridgid R86034 Direction Switch Replacement: 手順 6、 2の画像 2
    • Do not remove the direction switch.
    • Pull out all electrical components from housing by hand.
    • Lift out the motor.
    • Follow the wires.
    • The components should come out of their respective slots with ease and require little force to lift out.
    • The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • Remember to precisely place all components in their correct slots with their correct orientations when reassembling.
  7. Ridgid R86034 Direction Switch Replacement, Direction Switch: 手順 7、 1の画像 1
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Sean Liston
メンバー登録日: 04/28/15
311 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 15-5, Amido Spring 2015 Cal Poly, Team 15-5, Amido Spring 2015人のメンバー
CPSU-AMIDO-S15S15G5
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 27
今までの合計 1,534
