はじめに
Use this guide to replace a damaged or faulty trigger in your Ridgid 860054 Drill.
The drill trigger causes the drill to rotate when pressed. If the trigger is blocked or damaged, it won’t press or it is otherwise faulty, you will be unable to power on and control the drill.
Be sure to cross out all other possibilities on the troubleshooting guide before doing this replacement. It is possible that the drill trigger is still functional. There could be other issues preventing the drill from working instead of the trigger.
Make sure to remove the battery from the drill before beginning the repair.
必要な工具と部品
Using a T10 Torx security bit, remove the ten screws from the housing assembly.
Use a thin tool to disconnect the three prongs.
Remove the black plastic piece from the trigger body.
