メインコンテンツにスキップ
Ridgid R860054 Trigger Replacement
必要な工具と部品
  1. Ridgid R860054 Trigger Replacement, Ridgid R860054 Disassembly: 手順 1、 2の画像 1 Ridgid R860054 Trigger Replacement, Ridgid R860054 Disassembly: 手順 1、 2の画像 2
    • Using a T10 Torx security bit, remove the ten screws from the housing assembly.
    • All of the casing screws are the same length and require the same bit.
  2. Ridgid R860054 Trigger Replacement: 手順 2、 2の画像 1 Ridgid R860054 Trigger Replacement: 手順 2、 2の画像 2
    • Separate one half of the drill casing from the other by gently pulling both halves apart.
    • Once one half of the casing is removed, be careful! If the components are directed towards the ground, they could fall out.
  3. Ridgid R860054 Trigger Replacement: 手順 3、 3の画像 1 Ridgid R860054 Trigger Replacement: 手順 3、 3の画像 2 Ridgid R860054 Trigger Replacement: 手順 3、 3の画像 3
    • Remove the plastic speed switch and forward/reverse switch by softly lifting them from the casing.
    • Remove the internal components of the drill by lightly pulling on the drill chuck.
    • All of the other electronic components are attached to the chuck, and will come out with it.
  4. Ridgid R860054 Trigger Replacement: 手順 4、 1の画像 1
    • The main section of the drill should have the trigger, light indicator, and battery prongs all connected via wire. There should be two plastic switches separated from the rest of the body.
  5. Ridgid R860054 Trigger Replacement, Trigger: 手順 5、 3の画像 1 Ridgid R860054 Trigger Replacement, Trigger: 手順 5、 3の画像 2 Ridgid R860054 Trigger Replacement, Trigger: 手順 5、 3の画像 3
    • Use a thin tool to disconnect the three prongs.
    • Remove the black plastic piece from the trigger body.
    • On the new trigger, follow the same steps as above and remove the cap.
  6. Ridgid R860054 Trigger Replacement: 手順 6、 2の画像 1 Ridgid R860054 Trigger Replacement: 手順 6、 2の画像 2
    • Remove the trigger circuit from the plastic trigger body.
  7. Ridgid R860054 Trigger Replacement: 手順 7、 3の画像 1 Ridgid R860054 Trigger Replacement: 手順 7、 3の画像 2 Ridgid R860054 Trigger Replacement: 手順 7、 3の画像 3
    • Place the circuit into the new trigger and closure.
    • Place the plastic cap back on the trigger to secure the wire.
終わりに
作成者
3人の作成者と共同で作成されました。
Ryan Friedman
メンバー登録日: 03/13/23
109 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 1-1, Shaddix Spring 2023 UMass Dartmouth, Team 1-1, Shaddix Spring 2023人のメンバー
UMASSD-SHADDIX-S23S1G1
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 29
今までの合計 202
