はじめに
If the device will not turn on, the power switch could be at fault. If you have already tried blowing out dust, you may need to replace the power switch, which this guide will show you how to do. After removing the top cover with a Torx T10 screwdriver, you will only need a metal spudger to remove and replace the switch. Be sure that the device is unplugged when completing this replacement.
必要な工具と部品
Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
もう少しです!
終わりに
