メインコンテンツにスキップ
Ridgid JobMax R2851 Series B Motor Replacement
必要な工具と部品
  1. Ridgid JobMax R2851 Series B Motor Replacement, Motor: 手順 1、 2の画像 1 Ridgid JobMax R2851 Series B Motor Replacement, Motor: 手順 1、 2の画像 2
    • Unplug the device from the wall.
    • Orient the device so that the trigger is facing downwards.
    • Place your thumb and index finger on the two buttons located on the head of the tool.
    • Press the two buttons in and pull the head of the tool off.
  2. Ridgid JobMax R2851 Series B Motor Replacement: 手順 2、 1の画像 1
    • Loosen all eight 15mm T10 Torx screws.
    • You do not need to fully remove the screws yet; just loosen them enough that the device shell starts to open.
  3. Ridgid JobMax R2851 Series B Motor Replacement: 手順 3、 1の画像 1
    • Orient the device so that the cord end is facing upwards.
    • Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
    • Make a shallow cut to avoid damaging internal hardware.
  4. Ridgid JobMax R2851 Series B Motor Replacement: 手順 4、 2の画像 1 Ridgid JobMax R2851 Series B Motor Replacement: 手順 4、 2の画像 2
    • Completely remove all eight 15mm T10 Torx screws.
  5. Ridgid JobMax R2851 Series B Motor Replacement: 手順 5、 3の画像 1 Ridgid JobMax R2851 Series B Motor Replacement: 手順 5、 3の画像 2 Ridgid JobMax R2851 Series B Motor Replacement: 手順 5、 3の画像 3
    • Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
    • Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
    • Watch out for the locking mechanism for the head of the device when removing.
  6. Ridgid JobMax R2851 Series B Motor Replacement: 手順 6、 2の画像 1 Ridgid JobMax R2851 Series B Motor Replacement: 手順 6、 2の画像 2
    • Grip each of the sides of the two green circuit boards and slide them up.
    • Grip each side of the device trigger, and slide it up.
    • You do not need to completely remove these parts. Sliding them upward provides the needed room.
  7. Ridgid JobMax R2851 Series B Motor Replacement: 手順 7、 2の画像 1 Ridgid JobMax R2851 Series B Motor Replacement: 手順 7、 2の画像 2
    • Grip the motor firmly and pull towards the back of the tool, rotating back forth until the motor is free.
    • When reinstalling the motor, use a spudger to pull back the brushes. This allows the motor to slide into place.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Brent Shepherd
メンバー登録日: 02/12/19
905 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G5, Virtue Spring 2019 Western Carolina University, Team S1-G5, Virtue Spring 2019人のメンバー
WCU-VIRTUE-S19S1G5
4 メンバー
10のガイドは作成済み
1件のガイドコメント
Stops running trigger won’t depress in either position.
Gym - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 950
