Ridgid GEN5X R8653 Lever and Lever Spring Replacement
はじめに
This guide shows you how to replace the torsion levers for both the cutting depth and blade angle guides of the saw. These parts made out of plastic and will break if too much force is applied. For more information take a look at our troubleshooting guide.
Determine which lever needs to be replaced. The blade depth and cut angle levers are identical part numbers, but located in different areas on this saw.
The blade angle lever is located on the front left of the saw and connects to the base assembly.
The blade depth lever is located toward the rear of the left side of the saw behind the motor shroud.
