はじめに
If you need access to the inner workings of your Rigid 5X, this guide will help you remove the outer casing. You will need to use Torx t15 to remove each of the outer screws on the drill. Once all of the outer casing screws have been removed, you will be able to safely remove the outer case.
必要な工具と部品
Orient the drill to have the side with the screws facing up.
Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
もう少しです!
終わりに
