メインコンテンツにスキップ
Ridgid GEN5X R8611506 Gears Replacement
必要な工具と部品
  1. Ridgid GEN5X R8611506 Gears Replacement, Outer Case: 手順 1、 2の画像 1 Ridgid GEN5X R8611506 Gears Replacement, Outer Case: 手順 1、 2の画像 2
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Gears Replacement: 手順 2、 3の画像 1 Ridgid GEN5X R8611506 Gears Replacement: 手順 2、 3の画像 2 Ridgid GEN5X R8611506 Gears Replacement: 手順 2、 3の画像 3
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Gears Replacement: 手順 3、 2の画像 1 Ridgid GEN5X R8611506 Gears Replacement: 手順 3、 2の画像 2
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Gears Replacement: 手順 4、 2の画像 1 Ridgid GEN5X R8611506 Gears Replacement: 手順 4、 2の画像 2
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
  5. Ridgid GEN5X R8611506 Gears Replacement, Speed Selector Switch: 手順 5、 1の画像 1
    • Locate the selector switch.
    • Unhook the selector switch from the small silver wire located near the top of the drill.
  6. Ridgid GEN5X R8611506 Gears Replacement: 手順 6、 1の画像 1
    • Remove the speed selector switch from the case housing.
  7. Ridgid GEN5X R8611506 Gears Replacement, Gears: 手順 7、 1の画像 1
    • Pull the motor and chuck out of the drill casing.
  8. Ridgid GEN5X R8611506 Gears Replacement: 手順 8、 2の画像 1 Ridgid GEN5X R8611506 Gears Replacement: 手順 8、 2の画像 2
    • Orient the motor and chuck to where the back of the motor is facing up.
    • Using a Phillips #0 screwdriver, remove the four 5.0mm screws that connect the motor to the chuck.
  9. Ridgid GEN5X R8611506 Gears Replacement: 手順 9、 2の画像 1 Ridgid GEN5X R8611506 Gears Replacement: 手順 9、 2の画像 2
    • Pull apart the motor from the chuck to expose the gears.
    • Remove the four gears located within the motor/chuck housing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Harrison Essary
メンバー登録日: 02/05/19
611 ポイント
6のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 24
今までの合計 739
