はじめに
Use this guide to replace the forward/reverse switch in your Ridgid 860054 Drill.
The forward/reverse switch is also known as the rocker switch.
The forward/reverse switch allows you to change the direction in which your drill rotates. If it is damaged or otherwise unusable, you will be unable to change the direction of rotation of the drill.
Though unlikely, there may be other issues interfering with the function of the forward/reverse switch. Make sure to visit the troubleshooting guide before proceeding with the repair.
必要な工具と部品
Using a T10 Torx security bit, remove the ten screws from the housing assembly.
Remove the broken forward and backward switch by lifting it off of the trigger.
ある他の人がこのガイドを完成しました。
