メインコンテンツにスキップ
Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement
必要な工具と部品
  1. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Ridgid R860054 Disassembly: 手順 1、 2の画像 1 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Ridgid R860054 Disassembly: 手順 1、 2の画像 2
    • Using a T10 Torx security bit, remove the ten screws from the housing assembly.
    • All of the casing screws are the same length and require the same bit.
  2. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: 手順 2、 2の画像 1 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: 手順 2、 2の画像 2
    • Separate one half of the drill casing from the other by gently pulling both halves apart.
    • Once one half of the casing is removed, be careful! If the components are directed towards the ground, they could fall out.
  3. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: 手順 3、 3の画像 1 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: 手順 3、 3の画像 2 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: 手順 3、 3の画像 3
    • Remove the plastic speed switch and forward/reverse switch by softly lifting them from the casing.
    • Remove the internal components of the drill by lightly pulling on the drill chuck.
    • All of the other electronic components are attached to the chuck, and will come out with it.
  4. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: 手順 4、 1の画像 1
    • The main section of the drill should have the trigger, light indicator, and battery prongs all connected via wire. There should be two plastic switches separated from the rest of the body.
  5. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Reverse and Forward Switch: 手順 5、 2の画像 1 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Reverse and Forward Switch: 手順 5、 2の画像 2
    • Remove the broken forward and backward switch by lifting it off of the trigger.
  6. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: 手順 6、 2の画像 1 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: 手順 6、 2の画像 2
    • Replace the reverse switch with a new a switch.
    • Ensure the switch is inserted properly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
gage.anastasio
メンバー登録日: 03/15/23
339 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-1, Shaddix Spring 2023 UMass Dartmouth, Team 1-1, Shaddix Spring 2023人のメンバー
UMASSD-SHADDIX-S23S1G1
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 20
今までの合計 195
