メインコンテンツにスキップ
Ridgid Angle Grinder R10202 Motor Housing Replacement
必要な工具と部品
  1. Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: 手順 1、 2の画像 1 Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: 手順 1、 2の画像 2
    • Use a flathead screwdriver to unscrew the brush holder cap.
  2. Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 2、 2の画像 1 Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 2、 2の画像 2
    • Using your fingers, gently lift the carbon brush up and out of its housing.
    • Repeat these steps to remove the other carbon brush on the opposing side.
  3. Ridgid Angle Grinder R10202 Motor Housing Replacement, Motor Housing: 手順 3、 1の画像 1
    • Unscrew the side handle assembly from the gear housing assembly by hand.
  4. Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 4、 1の画像 1
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  5. Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 5、 2の画像 1 Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 5、 2の画像 2
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  6. Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 6、 1の画像 1
    • Lift the guard away from the output shaft assembly.
  7. Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 7、 2の画像 1 Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 7、 2の画像 2
    • Using a T25 Torx screwdriver, unscrew the four M5 X 28mm Torx screws.
  8. Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 8、 3の画像 1 Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 8、 3の画像 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: 手順 8、 3の画像 3
    • Grab the handle assembly and the gear housing assembly and gently pull apart.
    • Slowly pull the gear housing assembly out being careful not to damage the motor against the inside of the motor housing.
終わりに
作成者
4人の作成者と共同で作成されました。
Parker Massie
メンバー登録日: 01/10/19
607 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 18
今までの合計 840
