はじめに
Disassembling the handle assembly will be necessary for any rewiring or switch replacement needs. Jammed switches or a damaged power cord will require these preliminary steps for repair.
必要な工具と部品
Using a Torx T20 screwdriver, unscrew the five M5 x 16 mm screws.
Using the T20 screwdriver, remove the M5 x 28 mm screw.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
