Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
Use your fingers to completely remove the metal pin.
Remove the film compartment door.
The lens is only attached to the main camera body. Set the front and back covers aside.
Unscrew three screws from the outermost plastic plate covering the lens.
After the screws are removed, the outermost plate can be removed.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
