Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
Use your fingers to completely remove the metal pin.
Remove the film compartment door.
After removing the metal clip in the previous step, the front face plate can be removed.
The front face plate is attached to the camera body by two small wires. Carefully remove the plate and completely separate it from the camera body.
Unscrew the two screws that hold the button mechanism in place.
Press down on button mechanism to unlatch it from the camera body. When pressed down, the bottom of the mechanism should push outward.
Lift the button mechanism up carefully, removing the spring at the top of the mechanism from where it is attached to the camera body.
Remove the button mechanism.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
