メインコンテンツにスキップ
Ricoh Theta S Internal microSD Replacement
必要な工具と部品
  1. Ricoh Theta S Internal microSD Replacement, Outer Case: 手順 1、 1の画像 1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Internal microSD Replacement: 手順 2、 2の画像 1 Ricoh Theta S Internal microSD Replacement: 手順 2、 2の画像 2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Internal microSD Replacement: 手順 3、 3の画像 1 Ricoh Theta S Internal microSD Replacement: 手順 3、 3の画像 2 Ricoh Theta S Internal microSD Replacement: 手順 3、 3の画像 3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
  4. Ricoh Theta S Internal microSD Replacement, Battery: 手順 4、 2の画像 1 Ricoh Theta S Internal microSD Replacement, Battery: 手順 4、 2の画像 2
    • The battery is located near the bottom of the device.
    • Flip the plastic containing thermal compound over so it is resting on top of the battery.
  5. Ricoh Theta S Internal microSD Replacement: 手順 5、 2の画像 1 Ricoh Theta S Internal microSD Replacement: 手順 5、 2の画像 2
    • Lift the battery out of the device, beginning with the end closest to the camera.
  6. Ricoh Theta S Internal microSD Replacement, Internal microSD: 手順 6、 1の画像 1
    • Remove the two 2mm Phillips screws.
    • Remove the black 2mm Phillips screw.
    • Remove the 1.5mm Phillips screw.
  7. Ricoh Theta S Internal microSD Replacement: 手順 7、 3の画像 1 Ricoh Theta S Internal microSD Replacement: 手順 7、 3の画像 2 Ricoh Theta S Internal microSD Replacement: 手順 7、 3の画像 3
    • Carefully pull the side casing away from the camera.
  8. Ricoh Theta S Internal microSD Replacement: 手順 8、 3の画像 1 Ricoh Theta S Internal microSD Replacement: 手順 8、 3の画像 2 Ricoh Theta S Internal microSD Replacement: 手順 8、 3の画像 3
    • Lift up the plastic containing thermal compound to reveal the thermal tape covering the motherboard.
    • Peel back the lower left corner of the thermal tape to reveal the microSD slot located on the motherboard.
  9. Ricoh Theta S Internal microSD Replacement: 手順 9、 2の画像 1 Ricoh Theta S Internal microSD Replacement: 手順 9、 2の画像 2
    • Push the microSD card inward, from the side.
    • Once a click is heard, pull the screwdriver away to eject the microSD card from the slot.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Bradley Sutton
メンバー登録日: 11/07/17
737 ポイント
4のガイドは作成済み
チーム
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017人のメンバー
IUPUI-HARLEY-F17S3G1
3 メンバー
4のガイドは作成済み
8 件のコメント
I was able to complete this however there is a clear plastic guard running around the bottom half of the Theta S, and the only way to get the SD Card above that guard was to remove a few additional screws. Fortunately was not that complex and reassembly was still successful. Good luck!
jason - 返信
Maximum size of SD Card? 128GB?
just - 返信
I’ve not heard of anyone getting anything over 32gb to work, but I don’t think that’s definitive, as, even with 32GB cards, some would work and some wouldn’t. I think I might order a 64gb and try it out…
Basil Yokarinis -
I successfully replaced my microSD card with a transcend 32gb card, and it’s working. Only thing is, I ended up with 2 tiny braided wire sleeves that fell out during the process, and I have no idea where they are supposed to be. Also, before the repair, I had, an error come up at random and stop interval shooting (while there was still space available and power):
_cameraError":[“FORMAT_CARD”]
Now, after the repair, the error is:
_cameraError":["FORMAT_INTERNAL_MEM"]
And it’s constant, but, aside from causing the red lamp to blink always, and also beeping when I turn it on, it doesn’t seem to affect the function of the camera.
One point to improve the tutorial would be in step 8, in the 3rd picture, there’s a metallic, odd shaped piece sitting at an angle in the picture. This piece fell out when I was working to replace the microSD card, and I had to search other tutorials to figure out where it had to go.
Basil Yokarinis - 返信
Correction, it was a Sandisk Ultra
Basil Yokarinis -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 40
今までの合計 3,858
