はじめに
This guide will show how to replace the camera assembly for the Ricoh Theta S. Be aware that any replacement of disassembly of the original product may void the manufacturer warranty.
必要な工具と部品
Wedge the spudger underneath the small plastic square located on the bottom of the device.
Move the spudger to remove the plastic cover.
Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
Insert the plastic opening tool in between the panels shown.
Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
Lift the panel from the device.
thank you for the instructions. Keep in mind that the Spring clips are just on the other side of the phone, the side without the photo button. Then metal casing is attached to the front and can bend easy. So be careful here. If you get a red light, 5 beeps, and the device turns off, it means you’ve got a physical error code, and you need to investigate. In my case, I disconnected one of the flex cables to one of the cameras, and this needed to be redone.
5 の人々がこのガイドを完成させました。
12 件のコメント
Hello, is there a way to replace the glass the cover the lens? I Have 2 Ricoh Theta, one the glass is broken and other has a scratch that shows in every image… so I want to replace the scratched glass with the good one of the other camera
I also have same issue… Broke part of my glass, will like to find out if its possible to replace just one part of it….
I have one with a shattered lens and took it appart to check…. glass seems to be permanently fixed to optical block with very strong epoxi resin and doesn’t seem to be replaceable even if you manage to clean up, the problem is how to remove a good lens for transplant, without breaking it.
Hola abra repuestos para la richo theta s? Se me cayo y se rompio el lente . Se ve pero borrodo
Por supuesto en AliExpress.
https://aliexpress,com
I finaly change the front lens by unscrewing the arrow who hold it. You need a tool to grap it.
Hi Ciprian.
Where did you find a lens.
Kyle
My theta lens broke after a fall.. I was wondering where did u purchase ur camera Assembly?? Or where did u buy the lenses from??
I have problem with my camera, the front glass is cracked… how can I get it repaired?
