メインコンテンツにスキップ
Ricoh Super 8 800z Eye Battery Replacement
必要な工具と部品
  1. Ricoh Super 8 800z Eye Battery Replacement, Eye Battery: 手順 1、 2の画像 1 Ricoh Super 8 800z Eye Battery Replacement, Eye Battery: 手順 1、 2の画像 2
    • First, check if the battery is still working.
    • The Ricoh Super 8 800z comes with two battery meters in the back side of the camera. The button labeled "MOTOR" tests the AA batteries in the handle. Pressing the "METER" button will test the eye battery.
    • Press the "METER" button. If the needle on the gauge above goes to red, the battery is dead and needs replacing. If it is on blue, the battery is working and does not need replacement.
  2. Ricoh Super 8 800z Eye Battery Replacement: 手順 2、 3の画像 1 Ricoh Super 8 800z Eye Battery Replacement: 手順 2、 3の画像 2 Ricoh Super 8 800z Eye Battery Replacement: 手順 2、 3の画像 3
    • To remove this eye battery cover, place the camera on soft and stable surface, apply even and firm pressure around the metal cap, and unscrew it counter-clockwise.
    • The cover for the eye battery is the circular and ridged metal cap on the back-most part of the left fascia.
    • If it does not unscrew with your hand alone, you can use pliers and cloth to loosen it. Place a small cloth rag on top of the cap, grab the sides of the cap with the pliers, making sure to keep the cloth between the pliers and the camera to avoid tooling marks and any damage. Turn counter-clockwise until the cap loosens. Then unscrew by hand.
  3. Ricoh Super 8 800z Eye Battery Replacement: 手順 3、 3の画像 1 Ricoh Super 8 800z Eye Battery Replacement: 手順 3、 3の画像 2 Ricoh Super 8 800z Eye Battery Replacement: 手順 3、 3の画像 3
    • To remove the battery, simply turn the camera over with the open battery port facing down over a soft surface. Gravity should drop it out.
    • If it is stuck, just lightly tap the opposite side of the camera until it releases.
  4. Ricoh Super 8 800z Eye Battery Replacement: 手順 4、 2の画像 1 Ricoh Super 8 800z Eye Battery Replacement: 手順 4、 2の画像 2
    • If your battery port happens to be corroded. Get a small cloth rag held with small needle nose pliers or tweezers and wipe it away.
    • For heavy amounts of corrosion use a little bit of vinegar on the cloth and use to remove. Wipe the vinegar away after with a clean and dry cloth.
    • Allow the battery terminal to sit open and dry for an hour or so if vinegar is used.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
carlos enrique
メンバー登録日: 01/30/20
335 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 11
過去 30 日: 26
今までの合計 1,109
