必要な工具と部品
I decided I would try to design and order a small batch of flexible PCB as a replacement of the fragile ribbon - the achiles heel of all GR1's;
If anyone is willing to donate their dead GR1 for this project, I would try create the input data for the manufacturing of the flexible PCB (Gerber file) and order a small batch of PCBs. I would then make the files available open source.
So, Is anyone willing to donate the GR1 body? I am paying for the shipping and offer also one of the new ribbon PCBs as a reward.
Disclaimer: It is still just an idea, and I can't guarantee it will work. However if it turns out the way I hope, this could resurrect hundreds of crippled GR1's with failing LCD or VF lines.
There are 4 Philips head screws that must be removed to open the top of the camera.
2 are under the leatherette, one on the front and one on the back
be careful when removing the plastic piece around the eyepiece, there is a hook holding the right hand side farther from the visible screw.
There is also one long screw accessible from the inside near the film take up spool.
You will see the LCD and a bunch of flexible circuit boards soldered on top of each other
To continue disassembly further you will need about 20-30W "pencil" soldering iron
If you want to replace the conductive tape and restore lost segments of the top status LCD or viewfinder icons, you will also need a "3M Electrically Conductive Adhesive Transfer Tape 9703" (product page) Usually can be bought on ebay in smaller quantities.
Buttons should stay with the top cover as can be seen in the picture without anotations
There are some connections you need to desolder and one screw you need to remove.
the red circled solder joints may need to be desoldered (see comments below guide), I am not sure about the green circled, but try not to if possible
the flexible circuit board is held by strong double sided tape and it might appear that you need to desolder more joints, when it's actually just the tape holding it.
Your goal is to get to state like in the second picture, where I've bent the flex circuit boards open to gain access to the white flexible ribbon cable
This is the hardest part, and it's very difficult to take pictures of or describe.
you need to somehow gently detach the white ribbon cable from the LCD / flexible circuit board / viewfinder LCD (replacing ALL 3 conductive tapes may not be necessary, see comments below guide)
The ribbon is very fragile, and in all those connections is covered with a transparent tape to add strength to the connection
Be sure to clean both surfaces with alcohol and remove any residue of previous conductive tape
Before reattaching simply cut appropriate size of new conductive tape and apply to the ribbon, then press in the right place
reattaching to the flex circuit board is the easiest, because you actually see the copper paths which need to align with the black stripes of the ribbon
reattaching to the viewfinder LCD is more difficult, you need to align the right hand side edge of the ribbon
reattaching to the LCD is by far the hardest. On the LCD itself you can just barely see the conductive paths when you look at an angle. They are made of ITO (Indium Tin Oxide) and nearly transparent. I made marks where the rightmost and leftmost condctive paths are with a sharpie on the other side of the glass, and then glued the ribbon back on
If you've done everything right, you should see all segments on the the top LCD and in the viewfinder
it took me several tries to reattach the ribbon to the LCD and viewfinder LCD, patience and steady hands is the key to success.
Try not to damage the ribbon too much when detaching it. I did and had to shorten it slightly and in the end I had problem to fit the parts back together.
Reassembly should be just reverse order of disassembly. Don't forget the rewind button.
When you're at it, do yourself a favor and buy some leather sheets from Aki Asahi and give your GR1 a new covering.
4 の人々がこのガイドを完成させました。
11 件のコメント
Dear Ondrej, first of all, thank You for the guide! I have repaired mine (GR-1s) successfully based on this. Only a few minor things:
1) I did not remove the LCD end of the ribbon (on the picture in step 4, left side, red circle just below the number "82")
If only the common end of the ribbon has the fault, it is enough to tear that one.
2) the worst part, that there is no 2nd chance, after somebody tear the ribbon. If the contacts broken at the end of the procedure... all the camera could go to the bin.
3) I did not unsolder the backlight part - not needed. Maybe there is some difference between the models (GR1s vs GR1v)
Gyuri
Thank you for such a useful guide!! just a problem I encountered.
I tried to attach the ribbon cable to LCDs with the 3M tape you mentioned in the article. However, it appears that the bonding is not strong enough. I found that it sometimes need some pressure to hold the cable and the LCD stronger. Otherwise, the LCDs won’t function properly. Any suggestion for this problem?
By the way, I found that there are some sellers selling new replacing FPCs for the shutter of GR1 in China (about 12 USD per FPC).
Leo
Hey, thank for this guide. I have a similar problem with my R1s. Do you think I can use this guide to repair it?
Any luck with getting a donated camera? I have the lcd problem and I want to get it fixed. It kills me that such a (now) expensive and great camera gets crippled by something so goofy. I have the camera disassembled right now but I’m nervous to start the repair as I don’t want to completely destroy it.
To all GR1 users. I have just found a repair shop in Taiwan who can actually repair both LCD and shutter. They speak very little English but repair job is solid. FYI, GR1 is made in Taiwan so no wonder why they can repair the camera. Please contact them through Facebook. It may take time for them to respond as there are limited number of English speaking people in the shop.
I found that multiple sellers on AliExpress are selling the LCD together with the flex ribbon already attached, but I haven’t tried it and have no information if anyone has used it. It costs about 75 to 85 euros.
You would still need the conductive tape, and attach the flex ribbon at 2 places: to the circuit board, and to the viewfinder framelines LCD.
Ondrej Pok - 返信
I bought a new LCD from Aliexpress for my GR1s - however, the ones they sell seem to be suitable for GR1v (13 contacts on LCD, 20 contacts on camera PCB) and NOT GR1s (10 contacts on LCD, 17 contacts on PCB).
Does anyone know the pinout? Perhaps I can offset the LCD cable to make it work?
Happy to donate a GR1S (with this fault) if you are still looking.
Ollie Garside - 返信
Hey Ollie, I still didn’t get a parts body to get precise scans of the flex ribbon and get a replacement manufactured. Please send me an email to ondrej dot pok at gmail
Ondrej Pok -
