メインコンテンツにスキップ
Revlon One-Step Hair Dryer Lint Filter Replacement
必要な工具と部品
  1. Revlon One-Step Hair Dryer Lint Filter Replacement, Barrel: 手順 1、 1の画像 1
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 2、 3の画像 1 Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 2、 3の画像 2 Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 2、 3の画像 3
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 3、 3の画像 1 Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 3、 3の画像 2 Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 3、 3の画像 3
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
  4. Revlon One-Step Hair Dryer Lint Filter Replacement, Cord and Plug: 手順 4、 2の画像 1 Revlon One-Step Hair Dryer Lint Filter Replacement, Cord and Plug: 手順 4、 2の画像 2
    • Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
  5. Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 5、 1の画像 1
    • There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
    • Store screws in a safe place, you will need them to reassemble the device later.
  6. Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 6、 1の画像 1
    • Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
  7. Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 7、 3の画像 1 Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 7、 3の画像 2 Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 7、 3の画像 3
    • Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
    • Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
    • Next with your free hand carefully pull the cord out of the port of the dryer handle.
  8. Revlon One-Step Hair Dryer Lint Filter Replacement, Setting Dial: 手順 8、 1の画像 1
    • Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
  9. Revlon One-Step Hair Dryer Lint Filter Replacement, Lint Filter: 手順 9、 1の画像 1
    • Remove the air inlet by sliding it completely off of the wire.
  10. Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 10、 3の画像 1 Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 10、 3の画像 2 Revlon One-Step Hair Dryer Lint Filter Replacement: 手順 10、 3の画像 3
    • Take the lint filter out from the air inlet by peeling it from the sides.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Emma Grace Bender
メンバー登録日: 03/21/22
118 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team 1-4, Bedsole Spring 2022 University of Alabama, Team 1-4, Bedsole Spring 2022人のメンバー
UA-BEDSOLE-S22S1G4
3 メンバー
5のガイドは作成済み
コメント 1 件
I' just fixed mine following your instructions.. Thanks a lot for the share.
Lint Remover - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 69
過去 30 日: 377
今までの合計 14,005
