メインコンテンツにスキップ
Reupholstering a Couch Cushion
必要な工具と部品
  1. Reupholstering a Couch Cushion, Couch Upholstery: 手順 1、 3の画像 1 Reupholstering a Couch Cushion, Couch Upholstery: 手順 1、 3の画像 2 Reupholstering a Couch Cushion, Couch Upholstery: 手順 1、 3の画像 3
    • Remove the cushion from the couch. This will easily insure you to get the proper measurements of the cushion.
  2. Reupholstering a Couch Cushion: 手順 2、 3の画像 1 Reupholstering a Couch Cushion: 手順 2、 3の画像 2 Reupholstering a Couch Cushion: 手順 2、 3の画像 3
    • Using a tape measure, measure the height, width, and length the cushion.
  3. Reupholstering a Couch Cushion: 手順 3、 2の画像 1 Reupholstering a Couch Cushion: 手順 3、 2の画像 2
    • Replace the cushion with a new cushion.
    • In my case, I added a layer of new memory foam on the top and bottom of the existing cushion.
  4. Reupholstering a Couch Cushion: 手順 4、 1の画像 1
    • Draw out the measurements on the new fabric.
    • Take the measurements you gathered from Step 2 and measure/draw it on the new fabric to accurately cut the the fabric.
  5. Reupholstering a Couch Cushion: 手順 5、 2の画像 1 Reupholstering a Couch Cushion: 手順 5、 2の画像 2
    • Cut new fabric along your designated measurement lines.
    • Iron the newly cut fabric to prevent any wrinkles. This will help make for a more smooth and easy process.
  6. Reupholstering a Couch Cushion: 手順 6、 1の画像 1
    • Cover the cushion with the fabric
  7. Reupholstering a Couch Cushion: 手順 7、 2の画像 1 Reupholstering a Couch Cushion: 手順 7、 2の画像 2
    • Staple the fabric onto the cushion so it is secure enough that it will not come loose.
    • Once this step is completed, your cushion is all done and ready to be put back onto your couch!
    • If you would prefer: another way to secure the fabric around the cushion would be the sew it!
  8. Reupholstering a Couch Cushion: 手順 8、 1の画像 1
    • Final product!
終わりに
To reupholster your cushion, follow these instructions:
1. Remove the cushion(s) from the couch.
This will easily insure you to get the proper measurements of the cushion(s).
2. Using a tape measure, measure the height, width, and length of the cushion(s).
3. Replace the cushion with new cushion.
*In my case, I added a layer of new memory foam to the top and bottom of the existing cushion.
4. Draw out the measurements on the new fabric.
5. Cut and iron the new fabric to prevent any wrinkles. *This will help make for a more smooth and easy process.
6. Cover the cushion with the fabric
7. Staple the fabric onto the cushion so it is secure enough that it won’t come loose.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Tiffany St.Lifer
メンバー登録日: 01/21/20
187 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020人のメンバー
USFSM-STEWART-S20S1G1
23 メンバー
27のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 27
過去 30 日: 96
今までの合計 3,887
