メインコンテンツにスキップ
Retro-Bit Retro Duo Controller Button and Pad Replacement.
必要な工具と部品
  1. Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): 手順 1、 3の画像 1 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): 手順 1、 3の画像 2 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): 手順 1、 3の画像 3
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After screw removal, carefully lift the controller casing.
  2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 2、 3の画像 1 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 2、 3の画像 2 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 2、 3の画像 3
    • Pinch the top and bottom of the shoulder pads, then lift out.
    • There are small elastic pads below each shoulder pad. Replace these if they are not functioning correctly.
  3. Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 3、 3の画像 1 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 3、 3の画像 2 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 3、 3の画像 3
    • Carefully lift the circuit board from the controller case.
  4. Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 4、 3の画像 1 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 4、 3の画像 2 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 4、 3の画像 3
    • To replace the action button pad, lift this part out.
    • Lift the Select and Start button pad.
    • If replacing the D-Pad, lift this pad.
    • Pinch and lift the shoulder button pads.
  5. Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 5、 3の画像 1 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 5、 3の画像 2 Retro-Bit Retro Duo Controller Button and Pad Replacement.: 手順 5、 3の画像 3
    • Support the controller face and push buttons toward the inner case.
    • Use care. The buttons have a tiny tab to keep them in place.
    • Support the controller face and push the D-Pad toward the inner case.
終わりに
作成者
3人の作成者と共同で作成されました。
Evelyn
メンバー登録日: 09/25/17
223 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S4G4
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 20
今までの合計 1,184
