はじめに
The circuit board is essential to the console's functions. Using Phillips #0 and Phillips #2 screwdrivers, you can replace it.
必要な工具と部品
With the console on its top, remove the four 12 mm Phillips #2 screws.
Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
終わりに
1件のガイドコメント
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
