メインコンテンツにスキップ
はじめに
The USB-C port on your Retina MacBook 2016 is the only port besides the headphone jack, and may suffer wear or damage over time. Use this guide to replace it.
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges. Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case. Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  2. While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  3. Lift the upper case and display together from the front edge and raise it to about a 45˚ angle. It may be helpful to prop the MacBook open in this position for the next step.
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
  4. Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button. If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds. If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
  5. Close the MacBook and carefully flip it upside-down.
    • Close the MacBook and carefully flip it upside-down.
  6. Lifting from the front edge, open the lower case to an angle of about 45°.
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  7. Use tweezers to peel back the tape covering the trackpad cable ZIF connector. Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
  8. Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector. Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector. Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
  9. Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame. Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  10. Carefully close the MacBook and flip it over once again, so that the Apple logo faces up. Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it. Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
    • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  11. Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
  12. Remove the two screws securing the USB-C port cable bracket:
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Phillips #00 screw
    • 3.5 mm T5 Torx screw
  13. Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board. To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
  14. Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector. Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  15. Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
    • At this point it is possible to open the macbook all the way and to lay it flat on a table without causing any damage to the flex cables.
  16. Use tweezers to peel back the tape covering the display cable connector. Use tweezers to peel back the tape covering the display cable connector.
    • Use tweezers to peel back the tape covering the display cable connector.
  17. It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape. If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
  18. Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again.
  19. Disconnect the display cable by gently pulling it straight out of its connector.
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap.
    • The flap must remain closed when the cable is reinserted during reassembly. Line up the cable with the gold contacts facing down, and gently slide it into the closed connector. Take care not to crimp or damage the cable. When fully inserted, the indentations on the sides should not be visible.
  20. Separate the upper case assembly from the lower case assembly.
    • Separate the upper case assembly from the lower case assembly.
  21. Remove two 2.5 mm Phillips #00 screws securing the USB-C port.
    • Remove two 2.5 mm Phillips #00 screws securing the USB-C port.
  22. Use tweezers to lift the USB-C port just over the hinge screws. Slide the port out and up over the display hinge to remove it. There's very little clearance when removing and installing the USB-C port. If there's not enough room, don't force it. Try removing the display hinge screws and moving the hinges for additional clearance, if necessary.
    • Use tweezers to lift the USB-C port just over the hinge screws.
    • Slide the port out and up over the display hinge to remove it.
    • There's very little clearance when removing and installing the USB-C port. If there's not enough room, don't force it. Try removing the display hinge screws and moving the hinges for additional clearance, if necessary.
終わりに
13 の人々がこのガイドを完成させました。
Adam O'Camb
メンバー登録日: 2015年04月11日
135,200 ポイント
392のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
137 メンバー
16,041のガイドは作成済み
5 件のコメント
After replacing the USB-C port and plugged the computer into the charger, I did not hear the usual tone that lets me know that it is charging. I decided to leave it plugged in to see what happens. I also did SMC clear (Shift + Control + Option + Power) for good measure, but that did not appear to make a difference. After several minutes of charging, it made a tone, flashed a battery symbol on the screen, then booted.
woikelaw - 返信
An update from my USB-C replacement: it turns out that the USB-C replacement did not fix my MacBook. I found that if I powered it down then plugged it into the charger, it will charge.
woikelaw - 返信
Hi guys! I have a question about this. I have one usb c on my macbook pro 2016 TB that is not working properly. Sometimes I'm able to charge my macbook and sometimes not. In additional I cant use it to transfer data (backup my iPhone and so on). Also, i noticed that my battery is draining a lot with my mac turned off. It might be the case to change the IO board, or it could be worse than that?
Is there any correlation between this usb issue and the battery?
Appreciate your help
Andre.
André Bezerra - 返信
This repair worked great. The replacement USB-C port fits a little loose with the screws down tight, but maybe it’s designed that way. I had to hold the power down for what felt like a very long minute until it booted back up. Everything works and it’s charging! The fixit tool kit was a life safer.
Greg Zimmerman - 返信
It is very easy to break the USB -C ribbon cable while installing it. Does anyone have any particular advice for doing this without breaking the cable?
bfg737 - 返信
コメントを追加
統計データを表示:
過去 24時間: 9
過去 7 日: 59
過去 30 日: 252
今までの合計 11,456
