メインコンテンツにスキップ
Resetting Windows 10
  1. Resetting Windows 10, Open settings: 手順 1、 2の画像 1 Resetting Windows 10, Open settings: 手順 1、 2の画像 2
    • Press Windows + I to open your settings window.
    • Then click "Update & security"
  2. Resetting Windows 10, Recovery: 手順 2、 1の画像 1
    • From the settings window click "Recovery"
  3. Resetting Windows 10, Reset: 手順 3、 1の画像 1
    • From the recovery menu click "Get started" under "Reset this PC"
  4. Resetting Windows 10, Keep or Remove your files: 手順 4、 1の画像 1
    • You are then asked to choose one of two options. Pick one that would best suit your needs.
    • Keep my Files: This will keep any files you have stored in the windows Documents, Pictures and Videos folders etc. This will result in a fresh install of windows but keep all your files.
    • Remove everything: This will completely refresh the windows OS, free from any files or apps that where on before, any files stored on other drives or partitions will remain. Make sure you back up any data you want to keep before choosing this option.
  5. Resetting Windows 10, A few more clicks: 手順 5、 3の画像 1 Resetting Windows 10, A few more clicks: 手順 5、 3の画像 2 Resetting Windows 10, A few more clicks: 手順 5、 3の画像 3
    • After a short wait, windows will let you know what apps will be uninstalled. Click "Next"
    • After reading a quick overview of what is about to happen. Click "Reset"
  6. Resetting Windows 10, Lots of loading: 手順 6、 3の画像 1 Resetting Windows 10, Lots of loading: 手順 6、 3の画像 2 Resetting Windows 10, Lots of loading: 手順 6、 3の画像 3
    • The rest is automatic and will take some time. Make yourself a cup of tea and relax.
  7. Resetting Windows 10, Finishing touches: 手順 7、 3の画像 1 Resetting Windows 10, Finishing touches: 手順 7、 3の画像 2 Resetting Windows 10, Finishing touches: 手順 7、 3の画像 3
    • Once the reset is finished just log in as normal.
    • Windows will make a few final changes, and your done!
    • On your desktop will be a html file that will contain all the apps that were removed.
終わりに
16 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Conor Bailey
メンバー登録日: 04/27/16
7,968 ポイント
2のガイドは作成済み
チーム
Tech Haus Tech Haus人のメンバー
Business
1 メンバー
12のガイドは作成済み
2 件のコメント
Really nice information to the techies and readers... who want to do the job yourself.. I m sure anyone can reset the laptop , if he she follows the instructions mentioned here.
ncrsystemsolution - 返信
what if you forgot your password and you won’t open it. you want to reset your laptop what should i do?
John Paul - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 3,585
