はじめに
I am teaching you how to repair the hard drive of the HP 15-bs015dx laptop. You can consult a more complete disassembly guide on my profile
必要な工具と部品
Put the laptop facing down
Move the left battery safe lock to the right
Slide the right battery safe lock to the left
This lock is harder than the previous, with this the battery should pop-up.
Use a straw to take off just enough of the rubber feet of the 4 corners
Use a Phillips screwdriver 0
Replace each rubber foot in place after removing the screws
You will have a total of 10 screws
It will go out easily with or without a straw
You can check the model number
Flip the laptop and open it
Use a plastic tool or a straw to separate the pieces of the chassis
Flip the laptop and separate the inferior cover of the chassis
Hard Drive 2.5" SATA
2 RAM memory slots type DDR4 SO-DIMM
CPU Intel 7th generation
Active heat sink (fan)
Wireless card
Watch battery, 3V. CR2030
Se puede sacar su procesador?
No. En este caso, el CPU es un core i5-7200u, el cual usa un zócalo tipo BGA, es decir, usa soldadura para pegarse a la placa base.
Any info on how to swap out a non-backlit keyboard for a backlit keyboard for the 15-bs015DX? Thanks.
In this case, it looks like the whole plastic around the keyboard comes with it.
I can't be sure, since I no longer have the laptop. Try to disassemble it and look if they sell a drop-in keyboard replacementWhat type of m.2 it support, and what type of m.2 socket it have. Thank you.
M.2 SATA-3. But I don't see a space to put on the m.2 screw. I recommend you open it up and double check.
3 screws
Use a Phillips 0 screwdriver
Remove the frame
You don’t really need to remove the 2 black screws at this point. Once you remove the silver screw the hard drive and the frame will lift out. If you’re swapping the drive you will need to move the bracket to the new drive.
Tilt the hard drive up
Disconnect the hard drive from its SATA port
The hard drive is 7mm high. 1TB capacity.
For re-assembly of your device, follow these instructions in reverse.
9 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
6 件のコメント
Disculpa, yo tengo esta laptop, mi hard drive hdd se estropeó y quisiera cambiarlo por un ssd, sin embargo no se que tipo de ssd necesito, si eres tan amable de aclararme mi duda, se agradecería.
Saludos. Te toca comprar un SSD tipo SATA. Puedes revisar mi perfil, ahí tengo mis RRSS y me puede contactar.
Great but how do you get the software to reinstall on the new hard drive?
That would require a whole new guide. I have some of those on my YouTube channel, link in my ifixit profile.
Bottom line: A flash drive with a Windows installer on it.
Follow this POS guide and you WILL break the 4 mounting tabs for the hinges as NOTHING was mentioned about the 4 screws holding them down!
If you're referring to the screen holding hinges. This guide was never intended to replace the screen.
It's not required to unscrew the hinges to get to the hard drive, at all.
