メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
I am teaching you how to repair the hard drive of the HP 15-bs015dx laptop. You can consult a more complete disassembly guide on my profile
パーツ
パーツは指定されていません。
  1. Put the laptop facing down Move the left battery safe lock  to the right Move the left battery safe lock  to the right
    • Put the laptop facing down
    • Move the left battery safe lock to the right
  2. Slide the right battery safe lock to the left This lock is harder than the previous, with this the battery should pop-up. This lock is harder than the previous, with this the battery should pop-up.
    • Slide the right battery safe lock to the left
    • This lock is harder than the previous, with this the battery should pop-up.
  3. Use a Philips 0 screwdriver Use a Philips 0 screwdriver Use a Philips 0 screwdriver
    • Use a Philips 0 screwdriver
  4. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  5. Use a straw to take off just enough of the rubber feet of the 4 corners Use a Phillips screwdriver 0 Replace each rubber foot in place after removing the screws
    • Use a straw to take off just enough of the rubber feet of the 4 corners
    • Use a Phillips screwdriver 0
    • Replace each rubber foot in place after removing the screws
    • You will have a total of 10 screws
  6. It will go out easily with or without a straw You can check the model number
    • It will go out easily with or without a straw
    • You can check the model number
  7. Flip the laptop and open it Use a plastic tool or a straw to separate the pieces of the chassis Use a plastic tool or a straw to separate the pieces of the chassis
    • Flip the laptop and open it
    • Use a plastic tool or a straw to separate the pieces of the chassis
  8. Flip the laptop and separate the inferior cover of the chassis Hard Drive 2.5" SATA 2 RAM memory slots type DDR4 SO-DIMM
    • Flip the laptop and separate the inferior cover of the chassis
    • Hard Drive 2.5" SATA
    • 2 RAM memory slots type DDR4 SO-DIMM
    • CPU Intel 7th generation
    • Active heat sink (fan)
    • Wireless card
    • Watch battery, 3V. CR2030
  9. 3 screws Use a Phillips 0 screwdriver Remove the frame
    • 3 screws
    • Use a Phillips 0 screwdriver
    • Remove the frame
  10. Tilt the hard drive up Disconnect the hard drive from its SATA port The hard drive is 7mm high. 1TB capacity.
    • Tilt the hard drive up
    • Disconnect the hard drive from its SATA port
    • The hard drive is 7mm high. 1TB capacity.
終わりに
For re-assembly of your device, follow these instructions in reverse.
3 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
Marcos Mora
メンバー登録日: 2017年12月17日
698 ポイント
11のガイドは作成済み
3 件のコメント
Disculpa, yo tengo esta laptop, mi hard drive hdd se estropeó y quisiera cambiarlo por un ssd, sin embargo no se que tipo de ssd necesito, si eres tan amable de aclararme mi duda, se agradecería.
el_kevinsillo.777 - 返信
Saludos. Te toca comprar un SSD tipo SATA. Puedes revisar mi perfil, ahí tengo mis RRSS y me puede contactar.
Marcos Mora -
Great but how do you get the software to reinstall on the new hard drive?
Jared Brice - 返信
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 25
過去 30 日: 135
今までの合計 1,628
