メインコンテンツにスキップ
Replacing the Nokia 2115i Speaker
必要な工具と部品
  1. Replacing the Nokia 2115i Speaker, Nokia 2115i Battery: 手順 1、 3の画像 1 Replacing the Nokia 2115i Speaker, Nokia 2115i Battery: 手順 1、 3の画像 2 Replacing the Nokia 2115i Speaker, Nokia 2115i Battery: 手順 1、 3の画像 3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Replacing the Nokia 2115i Speaker: 手順 2、 2の画像 1 Replacing the Nokia 2115i Speaker: 手順 2、 2の画像 2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Replacing the Nokia 2115i Speaker, Faceplate: 手順 3、 3の画像 1 Replacing the Nokia 2115i Speaker, Faceplate: 手順 3、 3の画像 2 Replacing the Nokia 2115i Speaker, Faceplate: 手順 3、 3の画像 3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
  4. Replacing the Nokia 2115i Speaker, Removing the Keypad: 手順 4、 2の画像 1 Replacing the Nokia 2115i Speaker, Removing the Keypad: 手順 4、 2の画像 2
    • Note: The keypad will be loose and may fall off during this step.
    • Pull the face plate up and off of the phone.
    • To remove the keypad, simply lift it off the phone.
  5. Replacing the Nokia 2115i Speaker, Removing the Motherboard: 手順 5、 2の画像 1 Replacing the Nokia 2115i Speaker, Removing the Motherboard: 手順 5、 2の画像 2
    この手順で使用する道具:
    • Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard).
    • Note: 2 of the screws are on the bottom corners, 2 are on the right and left edges of the phone below the screen, and 2 are on the very top corners of the phone, above the screen.
    • Warning: The middle two screws are attached to the base of the phone with two black plastic rings. Use tweezers to remove the screws carefully to avoid breaking the plastic rings
    • Use a size T6 Torx screwdriver to remove each of these 6 screws.
  6. Replacing the Nokia 2115i Speaker: 手順 6、 3の画像 1 Replacing the Nokia 2115i Speaker: 手順 6、 3の画像 2 Replacing the Nokia 2115i Speaker: 手順 6、 3の画像 3
    • To remove the motherboard, lift it up and off the phone.
    • Note: The screen will still be attached to the motherboard.
  7. Replacing the Nokia 2115i Speaker, Nokia 2115i Speaker: 手順 7、 2の画像 1 Replacing the Nokia 2115i Speaker, Nokia 2115i Speaker: 手順 7、 2の画像 2
    • Turn the screen/motherboard so that the screen side is facing down. The first photo illustrates this step.
    • With your fingers, push the black tabs on the upper left and upper right sides of the motherboard outward. The second photo illustrates this step.
    • With the tabs pushed outward, you should be able to pull the screen off.
  8. Replacing the Nokia 2115i Speaker: 手順 8、 2の画像 1 Replacing the Nokia 2115i Speaker: 手順 8、 2の画像 2
    • Turn the motherboard so that the screen faces upward.
    • Holding the sides of the screen, pull the screen up and off of the motherboard.
    • Note: When you remove the screen from the motherboard, resistance is normal.
    • Replace old screen containing the speaker with a new screen/speaker.
    • Before reassembling, identify the two black plastic tabs on the screen/speaker, as seen in the 2 photos. When replacing the screen/speaker, make sure that these tabs are properly inserted just above the keypad.
    • To finish reassembly, follow the rest of the steps in reverse.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Shane
メンバー登録日: 09/30/10
80 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 14-38, Forte Fall 2010 Cal Poly, Team 14-38, Forte Fall 2010人のメンバー
CPSU-FORTE-F10S14G38
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 1,561
