はじめに
必要な工具と部品
Remove the P2 screws.
Remove the SIM and SD cards, as well as the adapter.
Pull off the protective cover from the camera.
Remove the screws with a #00 Phillips screwdriver.
Use a spudger to carefully apply pressure to the indicated areas to remove the cover.
Remove the microphone/speaker board assembly by pulling downward.
The battery has a small notch to facilitate removal, but the battery has been glued in place.
3 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
2 件のコメント
Umm not sure what BLU Vivo 5 your giving these instructions for, my BLU Vivo 5 has no screws. Looks the same except for bottom speaker area, mine has type c and other wither side 2 slots one for mic one for speaker, no screws.
This guide is NOT for BLU Vivo 5. It's probably for the mini version. The BLU vivo 5 doesn't have screws at bottom...
