メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Replacing graphics card in pc
必要な工具と部品
ビデオの概要
    • Power off the PC, and disconnect the power cable from the tower.
    • Open the side panel on the PC.
    • Some panels have clips that are easy to unlatch, and others have screws that need loosening. Only the panel that gives access to the components needs removing.
    • Remove the screw(s) holding the graphics card into the slot.
    • Unclip and remove any power cables connected to the GPU.
    • Release the PCI-e slot tabs that hold the GPU in place.
    • You may have to unlock it to release the card.
    • Place the card in the slot, and press down gently until it locks into place.
    • Ensure it’s fitted into the slot correctly and that both sides sit flush. When it’s locked in correctly, the tab on the slot should hold it in place.
    • Secure the new GPU to the slot with the screw(s) that was removed earlier.
    • Reconnect the power cables to the graphics card and power supply.
    • Startup the PC.
    • When the PC starts up for the first time after installing a new graphics card, it will search for the drivers.
    • It’s always worth using the latest drivers to ensure the best functionality and compatibility with the latest games.
    • Once the new GPU is working, it’s advisable to remove any redundant drivers and software used for the old graphics card.
終わりに
10 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Mark Blendy
メンバー登録日: 04/04/22
169 ポイント
1ガイドが承認済み
2件のガイドコメント
Before upgrading, it’s worth using a PC performance analyzer to check how well your parts will balance together. It helps avoid obvious CPU or GPU bottlenecks and saves money on mismatched upgrades.
Foster Daniel - 返信 共有
Thanks for the comment. That’s a good point and helpful advice.
Clark David - 共有
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 80
過去 30 日: 371
今までの合計 36,988
