メインコンテンツにスキップ
Replacing a Torn Bike Seat
必要な工具と部品
  1. Replacing a Torn Bike Seat, Bike Seat Cover: 手順 1、 3の画像 1 Replacing a Torn Bike Seat, Bike Seat Cover: 手順 1、 3の画像 2 Replacing a Torn Bike Seat, Bike Seat Cover: 手順 1、 3の画像 3
    • Use a wrench or electrical wrench to loosen the bolt located on the bike frame near the seat post.
    • Once the bolt is loose, pull the seat post out of the bike frame.
  2. Replacing a Torn Bike Seat: 手順 2、 3の画像 1 Replacing a Torn Bike Seat: 手順 2、 3の画像 2 Replacing a Torn Bike Seat: 手順 2、 3の画像 3
    • Orient the bottom of the bike seat so it's facing you, and place the short end of the Allen key into the bolt.
    • Rotate the Allen key counterclockwise to unscrew the bolt until the clamp is loose.
    • Slide the seat and seat clamp off the railings of the bike.
    • Keep track of the orientation of the seat clamp as you will have to reinstall the bike seat with the same orientation of the seat clamp.
  3. Replacing a Torn Bike Seat: 手順 3、 3の画像 1 Replacing a Torn Bike Seat: 手順 3、 3の画像 2 Replacing a Torn Bike Seat: 手順 3、 3の画像 3
    • Use a metal spudger to remove the staples on the perimeter of the bike seat.
    • Carefully peel the old leather material off the bike seat.
  4. Replacing a Torn Bike Seat: 手順 4、 2の画像 1 Replacing a Torn Bike Seat: 手順 4、 2の画像 2
    • Place your bike seat on top of the new leather material and measure out enough leather to generously cover the entire top and sides of the bike seat.
    • Mark a line around the perimeter of the material and cut along this line.
    • Make sure the foam of your bike seat is dry and free of moisture before proceeding to the next step.
  5. Replacing a Torn Bike Seat: 手順 5、 3の画像 1 Replacing a Torn Bike Seat: 手順 5、 3の画像 2 Replacing a Torn Bike Seat: 手順 5、 3の画像 3
    • Place the bike seat upright on a surface you don’t mind getting dirty and spray the foam seat thoroughly with adhesive spray.
    • Carefully press the cutout leather sheet onto the top of the bike seat.
    • Try to minimize wrinkles or air pockets to allow for a tight fit.
    • Smooth the leather out, and carefully apply the rest of the leather sheet to the remainder of the foam seat.
  6. Replacing a Torn Bike Seat: 手順 6、 3の画像 1 Replacing a Torn Bike Seat: 手順 6、 3の画像 2 Replacing a Torn Bike Seat: 手順 6、 3の画像 3
    • Keep all body parts clear of the heavy-duty staple gun and hold it firmly against the leather material.
    • Press the leather sheet down as close to the bike seat as you can in a desired starting location. Allow it to fold, if necessary.
    • Hold the staple gun directly against the leather and flush with the surface of the bike seat. Press down firmly, and staple the leather in place.
    • If the staple doesn’t go through on your first try, that is fine. Use the screwdriver to remove the staple, and try again.
    • Continue stapling the leather all around the bike seat until the leather is secure, folding or cutting excess as necessary.
  7. Replacing a Torn Bike Seat: 手順 7、 2の画像 1 Replacing a Torn Bike Seat: 手順 7、 2の画像 2
    • Use scissors to cut any excess leather from the inside edge of the seat.
  8. Replacing a Torn Bike Seat: 手順 8、 3の画像 1 Replacing a Torn Bike Seat: 手順 8、 3の画像 2 Replacing a Torn Bike Seat: 手順 8、 3の画像 3
    • Assemble the bike seat in the original clamp orientation that was observed in Step 2.
    • Slide the seat clamp onto the railing located on the underside of the bike seat.
    • Once positioned, insert the short end of the Allen key into the bolt.
    • Rotate the Allen key clockwise to screw the bolt in and tighten the seat clamp to the bike seat.
    • Make sure that the bike seat is positioned and tightened properly before usage to prevent injury.
  9. Replacing a Torn Bike Seat: 手順 9、 2の画像 1 Replacing a Torn Bike Seat: 手順 9、 2の画像 2
    • With the seat on the seat post, lower the post’s metal tube back into the bike’s seat post holder to your desired height.
    • Tighten the bolt on the bike frame following the instructions provided in Step 1.
終わりに
作成者
3人の作成者と共同で作成されました。
Pooja Mehta
メンバー登録日: 04/19/23
169 ポイント
1ガイドが承認済み
チーム
UCD-MORRIS-S23S1G7 UCD-MORRIS-S23S1G7人のメンバー
Community
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 584
