メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Replacing a Baseball Bat Grip
必要な工具と部品
  1. Replacing a Baseball Bat Grip, Baseball Bat Grip: 手順 1、 3の画像 1 Replacing a Baseball Bat Grip, Baseball Bat Grip: 手順 1、 3の画像 2 Replacing a Baseball Bat Grip, Baseball Bat Grip: 手順 1、 3の画像 3
    • Place the bat on a firm surface with the grip hanging off the edge.
    • Draw a line on the top of the old grip using a marker.
    • Practice caution when using the utility knife.
    • Use the utility knife to cut the tape where you made your mark.
    • Peel off the old grip.
    • Some bats may have an under layer of wrap that will require extra peeling to remove.
  2. Replacing a Baseball Bat Grip: 手順 2、 2の画像 1 Replacing a Baseball Bat Grip: 手順 2、 2の画像 2
    • Put on gloves and place the paper towels under the bat handle to catch the excess spilled residue cleaner.
    • Apply the residue cleaner to the handle.
    • Scrub off the residue with a rag.
  3. Replacing a Baseball Bat Grip: 手順 3、 3の画像 1 Replacing a Baseball Bat Grip: 手順 3、 3の画像 2 Replacing a Baseball Bat Grip: 手順 3、 3の画像 3
    • Sit in a chair and hold the bat in-between your legs with the knob facing upwards.
    • Take the pre-wrap, begin at the knob of the bat and wrap downward in a spiraling motion toward the mark.
    • When applying the pre-wrap, be sure to keep it evenly layered as it will quickly get thicker when doubled.
    • Stop applying the prewrap at the marked line.
  4. Replacing a Baseball Bat Grip: 手順 4、 3の画像 1 Replacing a Baseball Bat Grip: 手順 4、 3の画像 2 Replacing a Baseball Bat Grip: 手順 4、 3の画像 3
    • Hold the bat in the same position used for applying the pre-wrap.
    • Apply the electrical tape over the previous wrap using the same motion as before.
    • Be sure to evenly layer the tape to have a smooth wrap all the way down the handle.
  5. Replacing a Baseball Bat Grip: 手順 5、 2の画像 1 Replacing a Baseball Bat Grip: 手順 5、 2の画像 2
    • Apply a small piece of electrical tape at the beginning and end of the wrap to fasten it to the bat.
    • Now that your new grip is complete, you're ready to play ball!
ゴール
9 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Matthew McNabb
メンバー登録日: 09/11/15
164 ポイント
1ガイドが承認済み
チーム
Sam Houston State, Team 16-6, Nardone Fall 2015 Sam Houston State, Team 16-6, Nardone Fall 2015人のメンバー
SHSU-NARDONE-F15S16G6
5 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 82
今までの合計 65,794
