メインコンテンツにスキップ
Replacing VTech MobiGo Touch Learning System Speaker
必要な工具と部品
  1. Replacing VTech MobiGo Touch Learning System Speaker, Case: 手順 1、 1の画像 1
    • Remove the battery covers and the four batteries.
  2. Replacing VTech MobiGo Touch Learning System Speaker: 手順 2、 2の画像 1 Replacing VTech MobiGo Touch Learning System Speaker: 手順 2、 2の画像 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Replacing VTech MobiGo Touch Learning System Speaker: 手順 3、 2の画像 1 Replacing VTech MobiGo Touch Learning System Speaker: 手順 3、 2の画像 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Replacing VTech MobiGo Touch Learning System Speaker, Speaker: 手順 4、 2の画像 1 Replacing VTech MobiGo Touch Learning System Speaker, Speaker: 手順 4、 2の画像 2
    • The speaker will be attached to the back of the case.
    • Unscrew the two 6.0 mm Philips J0 screws.
    • Careful! The wires are still attached to the back of the case and to the speakers.
  5. Replacing VTech MobiGo Touch Learning System Speaker: 手順 5、 2の画像 1 Replacing VTech MobiGo Touch Learning System Speaker: 手順 5、 2の画像 2
    • Lift the round speaker with a plastic opening tool.
    • Remove the two wires connected to the speaker.
    • You can use wire cutters or regular needle nose pliers to disconnect the wires from the speaker.
    • Once the wires are disconnected, remove the speaker from the back of the case.
  6. Replacing VTech MobiGo Touch Learning System Speaker: 手順 6、 2の画像 1 Replacing VTech MobiGo Touch Learning System Speaker: 手順 6、 2の画像 2
    • Solder the wires to the appropriate spots on the new speaker, making sure that both wires are properly connected.
    • The wires may be hot.
  7. Replacing VTech MobiGo Touch Learning System Speaker: 手順 7、 2の画像 1 Replacing VTech MobiGo Touch Learning System Speaker: 手順 7、 2の画像 2
    • Insert the new speaker into the hatch located in the middle part of the panel using a plastic spudger.
    • Make sure the speaker is the right size for the panel.
    • Once the speaker is properly placed, screw in the two 6.0 mm Philips J0 screws.
    • Do not over tighten the screws or the panel will break.
終わりに
To reassemble your case, follow the case instructions in reverse order.
作成者
3人の作成者と共同で作成されました。
RBansil
メンバー登録日: 08/27/15
221 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015人のメンバー
USFT-EYESTONE-F15S8G3
3 メンバー
17のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 78
過去 30 日: 203
今までの合計 1,855
